Arlo Q - what is the shortest focal distance
  • 4 Replies
  • 5495 Views
craigjohnson
How close-up in inches can teh Arlo Q focus?
Thanks,
Craig
At least aprox 16 inches...may be closer
( looking thru glass at bushes in focus )
It's practically infinite. The Q lens equates to a 10mm focal length for 35mm or full frame DSLRs and is working on a much sampler sensor. Both will impact depth of field to the point that you almost need to be in physical contact with the lens to be out of focus.
craigjohnson
Thank you.
I need to be able to focus down to a distance of about 6 inches from the front of the camera lens.
Craig
You'd need to test to verify that distance. It may be fuzzy since these are really meant to work at a distance.
  • 4 Replies
  • 5496 Views
