Argo Q Plus says "No SD card plugged in" when card is in.
  • 1 Reply
  • 3256 Views
JosephineB
Got the Arlo Q Plus yesterday and plugged in a 128MB ExFat formatted San Disk SD card.   However, the app says "No SD card plugged in" although I can select SD Card Recording and Automatic Overwrite.  (Both are currently green on my phone.)   I took the card out and checked the formatting several times and the app still says "No SD Card".   ...Couldn't do a proper eject since the app wasn't giving me that option since it wasn't seeing the card to start.
So with the card in AND still having the message "No SD card plugged in", I decided to toggle the SD Card Recording button and I get the "Applying SD card settings" message up for a while (the wheel spins for 5 minutes or so)  but then nothing.  And the whole time the "No SD card plugged in" message remains.
I'd use the reset button until the camera clicks and the LED flashes amber. Resync and try using the card again. If no go, try a smaller capacity card or just another card of the same size.
The specs call for microSDHC or microSDXC card class 10 or higher cards - doeas yours comply?
  • 1 Reply
  • 3257 Views
