  • 8 Replies
  • 1578 Views
Ray1234
Can't log in with phone app
8 REPLIES 8
Still happening? WHat have you tried and what do you see? Try the web client (my.arlo.com) on a computer browser to see what happens.
Ray1234
The web page works fine. I just can't log in using Android. I've tired (after reinstalling of course) many times on my Samsung S21, another Samsung and an Android tablet. All of these deices respond the same. I enter my username, my password, and from there (after a short wait) the app simply removes my password leaves me at the same login screen.
When attempting to log in, does the screen show a link under the password to try a different authentication method? Try using that to see if you can then get in.
Ray1234
No, unfortunately the login screen only gives me the option of "Forgot Password". I've used that to reset the password but it still removes the password and leaves me at the login screen when I try to log in with the new password.
@JamesC , @ShayneS , @BrookeN can you help?
Ray1234
oks like those guys are not available. Anybody out there who might be able to help?
Ray1234
(looks like)
ShayneS
 Hi @Ray1234
Are you still experiencing this symptom?
  • 8 Replies
  • 1579 Views
