  • 4 Replies
  • 4466 Views
nordstrm
no matter where I place the Arlo Q, it doesn't connect. I am in the same room with two Arlo Q's now, one has full signal and works great, the other won't connect. they are three feet away from one another.
I would do a reset of the Q...hold in the reset button for aprox ten secs till the front led flashes..
re-sync and see if that fixes it
nordstrm
nordstrm
Thanks...i tried that and now it won't re-discover. Not sure what to do now. I do wonder if this particular unit is faulty.
I would do it again, remove the Q camera from the base ( use REMOVE DEVICE ) and then bring it back as if new ( add new device )....
If it fails again, it may be hardware, Contact Netgear Support ( or if recently purchased, exchange )
  • 4 Replies
  • 4467 Views
