  • 4 Replies
  • 2215 Views
manlikesbud54
Lose connection somewhere?
QueryString
What do mean by chage?
Assume you mean charge... Verify you are using the supplied ac adapter and cable
manlikesbud54
Yes with further inspection the connector that plugs into the camera . If held just right it will start to charge. Maybe getting a new adapter will solve problems?
michaelkenward
Sensei Sensei
Sensei
The Arlo Q Plus does not "charge". There isn't a battery to charge.
The power is there to keep the camera live.
It might be better if you explained what is happening at your end.
Just another user
  • 4 Replies
  • 2216 Views
