  • 2 Replies
  • 5186 Views
afekri71
HI
I want to buy Arlo Q plus. If the power voltage that we use in my country is 220v-240v, would it matter the power voltage since i'm coonecting the Arlo Q plus through ethernet cable from my router?
Abdul
PoE should be independent of any power supply since it's an Ethernet standard, rather like USB power levels.
WF
The power adapter that came with the camera has a label that states "110V to 240V" - which means that the camera can be used in countries with 110V power supply and 220 / 240V power supply. I have no problem using the Arlo Q camera that I bought from the US in my country which has 240V power supply - I just need to plug the camera power adapter into another plug that fits the power socket on my wall. No step-up or step down transformer needed.
  • 2 Replies
  • 5187 Views
