  • 4 Replies
  • 2484 Views
kringe
I bought an Arlo Q plus and  registered as a  new customer  on 24/12/2018
I did not add the rolling week of storage when setting it up.
Can i add it on after  i have set it up and tested it ?
kind regards
kringe
Account is just a section heading. The stuff under it are the account settings.
Use the Library tab to see your cloud recordings.
No need. You automatically get it. You only need to change things if you're upgrading.
kringe
Ok So please help change what settings do I do that.
All recordings are on the sd card at this time there is NO cloud
kind regards kringe
kringe
In my settings the account is greyed out
  • 4 Replies
  • 2485 Views
