Poor App and just Cannot Connect (Q & Q Plus Camera)
  • 2 Replies
  • 3532 Views
tjfan001
First of all, the Arlo app is so poorly designed. It requires the user to type in the network name! Why can't it auto detect the network that my iPhone is using, or at least put up a network list to choose from?
Then, after working for the first few months, the app just couldn't detect any devices at all. I've tried numerous time resetting the camera, seeing the lights blinking amber or blue (whatever), and the app could not detect devices at all. I've tried removing devices then adding them back, still didn't work! The app was just blind and couldn't detect anything!!
What a waste of money! So disappointed and pissed!!
tjfan001
I finally got them to work again by doing manufactural resets. That is, using a paper clip and insert the pin into the tiny hole that marked "reset". Then, the app was able to detect the devices. Apparently, something preset into the device, possibly the old network information, prevented the device to be detected by the app.
Still, a very painful experience indeed.
tjfan001
HONY
This is the first issue I have had and find the system great but you had better have at least 100Mb on the internet if you are using several Q's, Echos, Rokus etc.  I think the peripherals are getting ahead of the wifi G's. The indoor, outdoor cams have a booster modem to help but not the Q.  It might be why they offer a hard wire Q?  Not a techie, just guessing here.
  • 2 Replies
  • 3533 Views
