Arlo Q Plus WiFi Potential Solution
  • 0 Replies
  • 1502 Views
  • 1 In Conversation
RonySiddiki
Damn I found the solution of wifi prob at last. Well what you have to do is connect to wifi....
1. Use wifi setup as it is instruct from Arlo and connect with your wifi router. You can see the camera connected but can't discover by the app or web. Leave it for now.
2. Reset the camera again.
3. Do the same thing again for connect to the wifi
3. Use PoE connect from your PC Lan (Don't know why it works)  and login for discover the camera. It will discover in a sec.
4. Now you have the camera working!!!
Only Arlo or Netgear knows why it connect to wifi that way....but it works for me.
0 REPLIES 0
  • 0 Replies
  • 1503 Views
  • 1 In Conversation
