  • 2 Replies
  • 5499 Views
privacy2
Initial setup was with WIFI, no problems.  Decided to change from WIFI to wired connection.  Connected camera to ethernet, POE adapter connected to router, and connected USB cable from POE adapter to USB power adapter, to wall outlet.  Reset camera, setup recognized camera and all working including email notifications.  But soon after the camera was offline for a short period, no connection to ethernet, and this happens periodically.  This did not happen with WIFI connection.  I noticed in the user manual, when the ethernet is connect to a switch, the power adapter is not neccessary.  I have a switch available to connect to, instead of the router.  Should I change the ethernet from the router to the switch, and then remove the USB power adapter?  Thank you.
privacy2,
This will only work if the switch you are using supports power over ethernet.
It sounds like this could be a display issue, what is the LED behavior on the camera when it shows as offline? Do you have to do anything special to bring the camera back online or does it come back online by itself?
privacy2
It comes back online by itself within a short time, a few minutes I think.  I will look at LED next time it happens.  Thanks for the info regarding switch.  When I have time I will try to replicate and let you know, otherwise great indoor cam.
  • 2 Replies
  • 5500 Views
