  • 1 Reply
  • 1522 Views
elit3ge
Hi, Is anyone else having issues with their Arlo Q Plus just randomly reboot during the day?
Latest firmware, using ethernet and the wall plug. Recording at 1080 with the CVR, my upload speed is 30+mbps
I've done a factory reset not long ago so time will tell.
Could be the camera, cable or power supply (are you using PoE or the USB charger?). That's not normal behavior so try to nail down the part that's causing it.
  • 1 Reply
  • 1522 Views
