It seems that some camera/battery combinations need a bit of an extra push to make sure the battery is fully seated. Have you tried that? Have you swapped batteries around and tried just the power supply to see if the camera works in the first place? If it fails everything, swap at the store or open a case using the Contact Support link at the bottom here.
Most common issue is holding the base sync button to long...do a quick push on the base sync button and then a sec or so later push the camera button
syncing while camera plugged into outlet worked. I thought something was wrong with camera at 1st. not sure why this is a problem with last camera. it seems to be a recurring theme after reading all of the remarks. Netgear I think you need to pay attention to the issues and look into changing your instructions in the packets.
thank you Rcurrey Aspirant
I had the same problem of syncing and this did the trick-Many thanks for this tip!
