vmc4030 discharging fast i think
  • 2 Replies
  • 3192 Views
lildaddy75249
i just charged my battery to my arlo pro to 100% 2hrs ago and now its at 98%  i have my cameras set to off by app so there is no recording going on.  my cameras are inside house no more than 50ft from base  no motion or night vision on.   battery drained  2%.  i jus replace the battery that in the camera now.  any ideas?
I've had the batteries remain at 100% for some time (don't know how long). However, I'm not surprised that they would deplete some shortly after being charged. It's not like they're not totally off - they still need to maintain connection with the base. There could be a bit of a signal problem causing the cameras to have to work harder to maintain a connection. If it's only one camera, swap them around to see if it follows the camera or position. You might as well let them run for a while, too, to see if it was just an initial issue or continuing one.
lildaddy75249
will do thx
