Motion detection not working
  • 2 Replies
  • 4575 Views
Waterboy34
I recently purchased two camera pro set and motion detection and alerts were working great. Recently the motion detection stopped working and I noticed the running man on the ap is orange for both cameras. Is this correct or does is signify and error of some sort?
migman_2001
Luminary
Luminary
You might want to check the settings in Modes. I am a iOS user and had the same issue. I had to go into the web portal and set everything back. Afterwards, things have worked fine. A few others report the same issue. It seemed to only affect iOS users.
If iOS applies to you, make sure you have the latest app version installed and check your settings via the web portal.
A simple restart of the base may also clear your issue.
Good luck.
Maybe a power cycle of the base would help. What happens if you use a browser?
