hello all i turned my arlo pro system off over night batteries were good when i turn the system back on the next morning one camera battery was at 21% from 98%. any advice ? i jus replaced battery in the camera that loss battery power
The cameras were trying to reconnect to the base which was off. Never turn off the base without removing batteries. Better yet, just leave everything on and use either the Disarmed mode or the On/Off switch in Settings, My Devices, your cameras.
When you say that you turned the system off do you mean that you disarmed it?
Did you check the battery status using an app on your phone or the web interface?
You can try and reset the camera by opening and closing the battery door on the camera.
I guess it could also be a battery problem if resetting (and resyncing if necessary) does not resolve the issue.
yes i turn the base off i check batteries via web and i open and close battery door on camera
understand that part but the battery is draining to fast in 2 hrs
will do thx
