"Charging paused. Camera's battery temperature is too low." Any recommendation?
  • 3494 Views
  • 2 Likes
Ahipsley
Hello Arlo Community!
I'm trying to decipher the point of an outdoor camera when they can't withstand the cold? It's only 25° F outside right now. Ohio can get as low as -10° F. Should I be concerned about this winter? Is there any possible way around this? All 10 of my Arlo Pro cameras have this error and will not charge. Does anybody have any recommendations? Is it safe to say that these cameras aren't "Winterproof"? Thank you so much in advance!
Best regards,
AnnMarie
michaelkenward
Sensei Sensei
Sensei
The batteries are the weak link lies. Too cold and chemistry slows down. Apart from creating an insulating enclosure, the only solution for Arctic temperatures seems to be to remove the batteries from the process.
If you can find an outdoor power supply – Arlo makes them – this will still deliver power as the temperature drops. You can even remove the batteries from the cameras. But leave them in and the charger may deliver enough current to keep them warm enough to maintain a charge.
One advantage of this is that on "mains" power cameras can offer functions that are not possible on battery power.
Just another user
michaelkenward
Sensei Sensei
Sensei
Just another user
Ahipsley
Hello Michael,
Thank you so much for this solution! All of my outdoor Arlo cameras have already been hard-wired prior by me! I'm going to test it out by removing the batteries! Hopefully this can fix my issue. I'll keep you posted. It sounds reasonable to me. I completely forgot about how they function without a battery while plugged in. I also didn't realize that the battery chemistry was the culprit. I appreciate this so much 😄
All the best,
AnnMarie
storgeman
All batteries have issues with extreme Temps.  I have the opposite problem in sunny AZ.  When our Temps get upwards of 115, the batteries won't charge either.
