Since the most recent update I'm getting multiple duplicate notifications for a single motion event through the Android App. When motion is detected on any of my cameras I get about 4 notifications for the same event. Any one else experiencing this or have a solution?
Yes, this issue has been reported here. Everytime you uninstall and reinstall or clear the app data, it adds another notification sound. Try this:
Thank you @pc2k17! That did work (I'm not sure why or how) but the notifications appear to be back to normal - Thanks again for your help, greatly appreciated
