This entire forum is just a feel good way for Arlo to make it look like they are trying to address issues. Why does it go all the way back to 2016? The “new” required Arlo app download is a total bust and is causing all the old issues when Arlo tried a firmware update awhile back. Why wasn’t the new app tried and tested before requiring your end users / (supposed) customers to download it and utilize it. My camera charge is draining at a ridiculous. The motion detection (set @ 20) if it does work is so slow I only get a shot of the persons leg or arm as the exit off my porch. Arlo spend the money and get some real programmers on this issue, your forum is nothing but smoke and mirrors to cover up the major screw up and issues going on!
Sounds real low, most cameras need to run about 90% , the default is 80.
Sound detection should be in the camera rule(s) used by the mode. So try editing the mode, and look there.
On motion detection, try using the motion detection test for troubleshooting that.
