Also I am having issues with the time in the bottom right corner it will say 2 hours ago but the picture it shows was just a minute ago. If you click the live feed it will change the time to a minute ago. But when you stop the live feed it goes back to 2 hours ago.
It seems like the arlo app is made for Android and not iPhones. I never had issues on Android.
Hey @Ds89,
For the notifications, have you tried to reboot your iPhone and see if the experience is still causing the problem?
And for the live feed problem, are you experiencing this problem when you are on WiFi or on cellular data?
Hey @Ds89,
The live feed will lag on both WiFi and cellular data but not all the time.
Try to turn off the notifications for both for a few minutes and enable the notification again and try to monitor for a few days to see if you are having the problem.
If you are experiencing some live feed lag more frequent, try to reinstall the app and see if that resolves the lag issue.
What camera are you using? Have you tried to remove the battery and put it back in?
Make sure to download the latest app version, which is 2.6.2, and see if you should be able to toggle the animals and vehicles notification off through your iPhone.
Thank you and that worked now i can do that from my iphone. I am glad it updated to what Android was like.
