iOS APP armed symbol grayed out ​
  • 5 Replies
  • 4464 Views
thesaint580
When on schedule, the Garage camera activates from morning till evening. In the Arlo app on iOS, it shows Garage is active, but the armed symbol for Garage in Devices tab is grayed out. Having said this, the above issue doesnt exist on the web. The symbol is active when Garage routine is active on the web. Enclosed is a screenshot of the problem. Thanks in advance.
5 REPLIES 5
Ok, looked at app/web pic....but the question is , does it record video / sense motion when the web says it is on ?
I find the web much more stable than iOS
thesaint580
Yes, motion detection works fine even though it shows as not active in iOS app. So, seems to be a bug in the iOS app. This started to show up recently. Thanks again.
thesaint580,
Do you have the latest version of the iOS app installed from the app store? You might consider uninstalling your current version and downloading a fresh version from the app market.
thesaint580
I did and its still the same. I have this issue on 3 devices running latest app and iOS versions.
MilesSmith
it was working smoothly on my iPad Pro when it was running on ios 10 however as I have updated to ios 11.3 whenever now I am opening the app it only loads a blank screen on the startup and crashes after a while automatically. How do I fix it?
with regards
