When on schedule, the Garage camera activates from morning till evening. In the Arlo app on iOS, it shows Garage is active, but the armed symbol for Garage in Devices tab is grayed out. Having said this, the above issue doesnt exist on the web. The symbol is active when Garage routine is active on the web. Enclosed is a screenshot of the problem. Thanks in advance.
5 REPLIES 5
Ok, looked at app/web pic....but the question is , does it record video / sense motion when the web says it is on ?
I find the web much more stable than iOS
Yes, motion detection works fine even though it shows as not active in iOS app. So, seems to be a bug in the iOS app. This started to show up recently. Thanks again.
thesaint580,
Do you have the latest version of the iOS app installed from the app store? You might consider uninstalling your current version and downloading a fresh version from the app market.
I did and its still the same. I have this issue on 3 devices running latest app and iOS versions.
