  • 2 Replies
  • 3329 Views
greatdeals_007
how do you ensure camera is not recording while your home?
debating if I should put this in the family room where we spend most of our time. is there a shutter or light  to ensure camera is not recording while I am at home?  really concerned these cameras can get hacked.
Well in the beginning I used to put a sock over the camera... Or turn it to the wall  🙂
Now tho in SW under settings, there is a privacy ON/OFF switch... this will disable the camera from any viewing ( including you ).
That's exactly what it is there for.  ( esp good if you share the cameras with others, only the admin can toggle it on/off )
The camera if off goes to sleep mode like disarmed and is using very little power.
** there is/was a glitch with the pro... in OFF mode, motion would still trigger the IR illuminators tho now video was streaming... not sure if fixed yet.
While I haven't checked it since, my case on this was closed when I verified that the IR illuminators no longer turned on when in the Off mode after a firmware update.  SHould no longer be a problem.
