how do i use the back up storage when i want to save something
  • 3288 Views
jshriner
is there anyway to store videos to the backup storage such as a USB memory when there is one i want to save
steve_t
Master Master
If you plug a USB drive into your Arlo Pro base station, all of the recordings will be saved to the drive, but if you want to, you can just go to the arlo website or app and view recorded videos and download them to your device/computer.
The USB drive would need to be removed from the base and plugged into a computer if you want to view the contents of the drive
As above... remember that the same video that goes to the Library goes to the USB drive
AND, you must eject the drive ( like any other usb device ) properly so as not to damage files
Or just download the video(s) from the library.
