  • 6 Replies
  • 4164 Views
  • 5 In Conversation
pb633
want to keep previous app version for use with old devices- new one will not work.
pb633
chatted with Arlo rep and found out how to do what I needed in new app. could not locate manual for new system and pressing buttons was confusing and unproductive. works now. no further questions.
6 REPLIES 6
BrookeN
You can not go back to the previous app version. However, can you provide more information on what behavior you are seeing and what cameras you are using?
pb633
bwfarns
Need the prior app your forced update lost Samsung tablet and phone functions
bwfarns
Samsung model smt 580 an r52k70n7jmh 16g phone se 20fe Samsung PC laptop running windows 10
Peretti
I have an Arlo Pro. With the latest update, I am no longer able to delete the videos by "select all".  Live feed does not show any videos even though I have 95 today.  there is not three dots on the screen for selecting all, only three dots for each video, one at a time.  What am I doing wrong?
If you select the three dots at the top right of the "Feed" screen, then you should see two options:
Choose "Select Events" and you will see selectors for each video and for each day:
Selecting the day automatically selects all videos saved for that day.  When done, you select the trash can at the bottom of the screen to delete the selected videos.
I see these controls in both the web client (my.arlo.com) and the app.  One poster said that they only saw them in the app, and not the browser.  I don't what that should be, but if you aren't seeing "Select Events" in the browser, then I suggest trying the app.
