How do we remove the adjustable mount? The power adapter does not fit as the adjustable mount is in the way.
You can remove the camera instead of the mount... or swap battery packs by tilting down.
There also was a changed part on the mount for the Pro... the lock screw size on the mount size was modified.
Contact Netgear Support to see if they can help you with the newer part for the mount.
TomMac wrote:You can remove the camera instead of the mount... or swap battery packs by tilting down.
Hi Tom,
just wanted to pass on my experience with the new screw (as supplied by Netgear), it definitely solves the space problem. However it's quite smaller and difficult to grip and turn to tighten.
Paul
