have to swap batteries from different cameras to get them to charge
WHEN I CHARGE MY CAMERAS ,I HAVE TO SWAP BATTERIES FROM DIFFERENT CAMERAS TO GET THEM TO CHARGE . ANY ONE ELSE HAVING THE SAME PROBLEM.THE 4 CAMERAS. ARE 4 MONS OLD. sneaker235
Havent had a problem charging the cams (or my phone), with the Arlo provided charging cable.
My active cam gets charged once a week or so... my secondary cam has only been charged once since we bought it in mid Feb, and is currently at 80%.
Are you saying that you can't a particular camera in order to chrge its battery or that regardless of the camera and/or battery you have to swap them around? Just trying to nail down whether it's a bad charger connection on a particular camera.
Are you letting the battery charge fall below 15%. If so there is a procedure for recharging the batteries. I will try to find the article for you if you need it.
Brian
Below 15% isn't a problem. Flat dead is the issue and requires a bit of aa procedure to revive the battery.
THANKS I WOULD APPRECIATE IT. sneaker235
For what its worth I believe this is the article I read. This may only apply to the charger station accessory.
But you should be able to bring the camera in and plug it into the power adapter to charge the camera even if it is completely dead.
Brian
