cant discover base station vmb4000 or cameras after i changed internet provider
  • 6 Replies
  • 1679 Views
maxgen
Ive followed the instruction on resetting everything but after deleting my base station from the app i have not been able to connect since.  Ive done factory reset multiple times and the leds on the front seem to be right. first 2 green and third one amber for the cameras.  My main problem is trying to get the app to discover the base station then i believe i would be able to sync the cameras to it.  any ideas?? tia
6 REPLIES 6
Have you tried onboarding the base and cameras using a PC (browsing to my.arlo.com) instead of using the app.
Sometimes the PC will work for this when the app doesn't.
maxgen
yes I brought my laptop right next to the hub and tried everything a couple times..  same result. I cant even pay for a subscription to get help because it says I don't have any equipment tied to my account.
If the laptop has an ethernet port, maybe try connecting with that instead of wifi.
To be clear, don't connect the hub to the laptop, just try using an Ethernet cable between the laptop and router.
Also, if using a VPN, disable it for setup purposes.
maxgen
same result.  ive now deleted everything and tried to start from scratch, new account and still nothing.  my base is sending out a wifi signal.  i can see it on my devices.  maybe something happened to my base station when they unplugged it...idk  is there anything else to try?
Is the base getting an IP address from your router? Sounds like it but...
Can you take the base to someone else's house and try there?
