cann't sing in arlo account
Just bought a new arlo pro wire-free HD security camera system in syria and when I tried to register it I got a message " you are not connected to internet . please check your connection
5 REPLIES 5
Is it possible your ISP is blocking access to arlo.netgear.com?
ammore,
What is the LED behavior on the base station?
I tried another ISP somewhere else but the same result
they are all yallow
If the power LED is yellow/amber, you have a hardware issue. Power and Internet must all be green for things to work. Since the power LED is amber it could be the base or the power supply. You may be able to swap the system at the store or open a case with support using the Contact Support link at the bottom here.
