  • 2 Replies
  • 3614 Views
lindagc43
Hello, l am trying to charge my battery for a camera and have tried and re-tried using the adapter and charging station. Please suggest help?  thanks,
Streak2
Master Master
Are you using the adapter that came with the camera?
When trying to charge with the battery in the camera, what color does the led on the camera flash just after plugging in the USB cable? Does your app indicate that the battery is currently being charged?
You mention the charging station, do you mean the VMA4400C? If so, what do the light son the charging do once the battery is inserted and power is applied?
Pull the battery and replace, attempt to charge ...if still NG, contact Netgear Support
