Hi:
I purchased this system (4 cameras) this month. I put two cameras in outside house (one in front to catch drive-way, one in back yard), two cameras in the house. I want to set arm model for two cameras outside house all the time, and set disarm model for two cameras in the house. I found that when I set ARM mode for one, then 4 cameras all go es to ARM, How can I set the ARM or DISARM for each cameras individual camera. Can I set Model for each individual camera ARM/DISARM in different schedule?
Thanks!
James
You need to create a custom mode. Call it whatever you want. Mine is away (alll armed) and home (only outside cameras) . so on the away where it says add device add all your cameras then create another mode and leave off the inside cameras. Dont add them. You can even leave them on to live view they just wont be armed
You need to create custom modes and split up the cameras into groups...
remember any camera NOT in the acitvie mode is OFF
Camera not in active mode can be on or off. Its just not armed. I leave mine on so i can live view
