WiFi Radiation to intense
  • 1 Reply
  • 3986 Views
Shamji
When the Arlo Pro 2 base station is on, I feel dizzy and the head feels like it is stretching. Has  anyone else experienced this issue? When I switch it off the symptoms disappear.
 Are  Netgear aware of this WiFi health hazard and what are doing about it?
pc2k17
Hero
Hero
It isn't wifi per say, but the electromagnetic field (emf) that the electronic device creates. (wifi devices do create powerful emf's and are the main contributors of emf's in the home or office). Some devices put out stronger emf's than others and some people are more sensitive to emf's than others. It possible either you got a bad base or you are sensitive to the emf's that all the devices in your house are creating. I also suppose it's possible that when the arlo base is on, the emf from it, combined with the dozens of other emf's emiting from your electronic devices puts your body over the edge. There are things you can do like turning devices off and emf shielding products. Goggle or Bing emf makes me sick and hopefully you'll find some info that might help you.
