Camera will not turn on the external power supply
  • 1 Reply
  • 2446 Views
rrbd
I installed a camera and the Wasserstein outdoor power supply.  The signal strength display shows only 1 dot but the picture is good and reponds to the commands but will not turn on the external power supply.  Is this because I left the battery in the camera?  When brought closer to the ARLO hub the power supply is recognized and the camera works properly.  Should I get an additional WiFi extender?
rrbd,
We don't recommend you use any third-party accessories with your Arlo cameras. For outdoor user, we recommend using the VMA4900 outdoor power adapter, designed for use with compatible Arlo cameras.
