arlo pro I'm trying to hook it up but i don't have a big router ,just a small wi fi from at&t
  • 2 Replies
  • 3645 Views
jimboo
i am trying to hook it up but i just have a small wi fi with no port to plug the cable into . i dont have a big router what do i do ?
Streak2
Master Master
The best would be to get a switch.
https://www.netgear.com/support/product/GS105.aspx?cid=wmt_netgear_organic
Remove one Ethernet cable from your existing router and plug it into the switch and then plug a patch lead from the switch back into the vacant port of the router. Then you can use any of the remaining sockets on the switch for the Arlo.
steve_t
Master Master
If the wifi unit has no ethernet ports, I'd get this and connect it to your wifi and plug the Arlo base into it
http://www.netgear.com/home/products/networking/wifi-range-extenders/EX6100.aspx?cid=wmt_netgear_org...
