I have two Arlo Pro's set up outside, and they have been working fine for about six months. Now for some reason when I look at videos in the library they appear to have recorded as normal. When I playback Cam1 I see the right video, but when I playback Cam2 it also shows the Cam2 video. The still images in library are correct but playback is always wrong, and always for the same camera. I'm using the latest Android app, and I have tried uninstall/reinstall. My wife doesn't have the same problem on the iOS version. Suggestions?
This issue is resolved with the latest version of the Arlo Android app, which is version 2.13. Please make sure you have the latest version installed from the Google Play Store and let us know if you're still experiencing the same issue. You can read more about the new update here: Arlo Android App - 2.13 - 4th March 2020
This might sound screwy but please bear with me as I try to explain. Ever since 12/25/2019 I noticed that my recordings are showing up in my app as usual but when I go to play them it shows me a different camera recording. Example: I show a recording on the "Back Yard" camera but when I play the clip it is showing me a video from "Back Yard 2". I show a clip on "Front Yard 2" and the clip shows "Front Yard" or "Front Door". I have 6 cameras, (Pro, Pro 2 & the new Video Doorbell). I've removed and reinstalled all the mobile apps and still have the same issue. With the exception of the video doorbell I have taken down all the cameras, and did a remove device and reinstall and still have the same issue. I'm thinking this is a mobile app issue since it does not happen on my main computer. Anyone else notice this issue since the 25th?
https://community.arlo.com/t5/Arlo-Pro/Recordings-Backwards-Out-of-Order/m-p/1748723#M65859
Same here.
And cloud records still shorter than USB records by at least 2 seconds.
I am having the same issue on the Android app. Recordings in the library only playback from 1 camera no matter which one I choose.
I have sort of the same problem, I have 2 base stations on my app and when I go to modes base1 was always at the top and base2 was under it now sometimes when I open the app and go to modes base2 will be on top and base1 will be on the bottom. They always fix one thing on the app then break another.
Can pull up any camera from my laptop however when I try to pull up a video from the library on my Android device, it keeps playing the same video from days ago. Three attempts from the "off-shore" tech team and still no resolution. If I play the video immediately after a the camera detects motion, it plays but, once in the cloud it only pulls up the one video from days ago
I would delete the app and re-install same
Thanks Tom, I should have posted, re-installed app, cycled base station several times, pulled batteries out of all cameras, cycled router multiple times
Follow-up:
System works fine on IOS and Windows but not Chrome or Andriod ..Galaxy S9
I have the same problem. I believe it started last week. As an example, I have one camera set to start recording when another camera detects motion and starts recording too (two views of same basic area). The app shows the two recordings, but when I open the recording from the first camera (the one detecting motion), it shows the second camera's recording. The recording for the second camera is correct.
The recordings do appear to be correct online.
I never had issues viewing video clips on my cloud. Recently, as I go into the cloud for any one of my 5 cameras, I click on a video in the list and, after watching that clip and then trying to swipe to the next video for that camera, it changes to another one of my cameras. I can't watch multiple videos from the same camera without it changing camera views. I've tried uninstalling and reinstalling my app, I've unplugged my base and rebooted the system multiple times but it hasn't helped. Has anyone else had this issue? It seems to have started happening after a recent update but I can't be certain.
I'm not sure if others are annoyed by this changed to the software, but prior to the 12/24/2019 software update I was able select a specific camera, through "Device", and look through the videos for that camera, play the video and once the video was done or if I stopped the video it goes back to the camera's library.
Now when I go to the specific camera and play a video then stop it the software automatically goes to the "Library" and lists all the video for all the cameras in chronological order. I would have to go back to "Devices" to get the list and look through the library for the specific camera. I want to only look at the video library for that device NOT ALL devices.
Arlo please fix this issue and put the previous feature back.
Yes this is very annoying and hopefully It's just a bug and not a new feature, it works fine in the browser so It seems like it's just happening in the phone app. Please fix!
What version of the Arlo app are you using?
I have certainly noticed this also. Was hoping it was a glitch. When viewing videos, the software now defaults to "Library". Which I guess would be okay if you only had 1 camera set up in the system.
I have 5 cameras set up ---- when I want to look at video from Camera 1, i don't want to have to sort through the library to find it.
Arlo staff, please let us know if this is a glitch or an actually change to the software.
When I look in my Android Arlo App in the "Library" section it shows all the correct triggered Videos.
However, if I click any of the "Front Door" videos, it plays my other cam "Driveway" video. If I manually finger flip to the left, the next video is the correct Front door one.
FYI: When my Front door alerts, it is set to record both "front door" and "driveway". Maybe a recent Android App update caused this, as it doesn't happen in the Web Interface.
						Apple HomeKit1
						Arlo Mobile App449
						Arlo Pro27
						Arlo Pro 21
						Arlo Pro 32
						Arlo Secure1
						Arlo Smart102
						Arlo Ultra1
						Arlo Web and Mobile Apps6
						Arlo Wire-Free10
						Before You Buy1,206
						Discovery1
						Features237
						Firmware1
						Firmware Release Notes119
						Hardware2
						IFTTT1
						IFTTT (If This Then That)48
						Installation1,430
						Installation & Upgrade1
						Online and Mobile Apps1,266
						Partner Integrations1
						Security1
						Service and Storage563
						Smart Subscription1
						SmartThings39
						Software & Apps1
						Troubleshooting7,334
						Videos1
