I made a custom mode and within that mode i have set my driveway cam to trigger it and my front cam to record if motion is detected and vice versa. Im not home to test it. Will this work?
if you did it right , it should
Cam a senses, cam b records
cam B senses, cam A records
Yes, that'll work
To add to it, I have 2 cameras covering the same area and 4 rules in a custom mode
Camera A detects motion and Camera A records
Camera B detects motion and Camera B records
Camera A detects motion and Camera B records
Camera B detects motion and Camera A records
Sounds like you have the last two rules. If you want, you can add the first two
Yes thats how ive got mine. With 2 additional rules for my backyard and inside cam. Thanks for the help
