Why my arlo pro not restarting automatically after going offline
do you mean the base or cameras ?
If base, what are the leds showing
There was an issue that a small number of users were experiencing yesterday that resulted in a similar behavior. Engineering has since resolved the issue, are you still experiencing this today?
WillAstro,
What is the LED behavior on the base station?
That means your base is connected to the router but has no Internet access. Unless you've made some security changes to the router configuration, I would power off the router and base and then turn them back on in that order. Let the router initialize before starting the base.
Define "resetting" - using the reset button until the base LEDs flash amber? If so, you also need to remove all devices in Settings, My Devices before using the Add Device button to add the base and sync the cameras as if new.
