  • 6 Replies
  • 1659 Views
K57
Why do 2 Arlo hubs show up on my account
Bases with the siren built-in will show that - note the siren icon attached to the listing. The second/bottom one is the siren identification which you can rename to keep things straight if you need.
Best answers
  • jguerdat
6 REPLIES 6
We need some more information here.
In particular
  • Are both hubs shown as on-line?
  • Did you ever have a different hub than the one you are using now?
Screen shots would be helpful - perhaps using the browser (my.arlo.com).
K57
I’ve attached a photo.
Thx, that helps. Some hubs do show up that way - no idea why.
There's no way to fix it, but on the other hand it doesn't create any problems either.
K57
Thanks Stephen. Just wondered why it showed 2.
K57
Awesome! Thanks for responding. I would always wonder if you hadn’t.
