Why am I not getting recording in my Library?
  • 1 Reply
  • 1583 Views
Elaine3
Vmb4000
My Arlo pro will not record in my library
Need a lot more details. What mode are you using (Mode tab, select your base and check the selected mode)? Are the running men for each camera in the Devices tab black or gray (gray is disarmed)? What are the LEDs on the base shwoing, including color? Have you verified that the battery is charged? Can you use live view and manually record there? When looking in the library, is there a filter set (the funnel-looking icon at the top should be empty but may be filled in)?
