  • 2 Replies
  • 9584 Views
Douglasearl1
Arlo Pro was installed and worked fine for 8 days. Has stopped recording motion and therefore sends no notifications. Two cameras installed and both not working. What has happened or what have I done wrong. Can view live video. Batteries charged.
Check and confirm the cameras are ARMING... go to Mode and Arm cameras, then go to Live View screen...
confirm the "running man" is BLACK and not gray.   Only will record on motion if the man is Black
ShayneS
Hi Douglasearl1,
Here are a few links with some good info you may look in to:
Arlo Wire-Free, Arlo Pro Wire-Free, Arlo Pro 2 Wire-Free, and Arlo Go cameras trigger when the infrared technology detects an object that is warmer than the surrounding environment. The motion sensor is more sensitive to side-to-side movement across its field of view than to movement directly toward or away from the camera. The motion sensitivity settings range from one (low sensitivity) to 100 (high sensitivity).
For more information about motion detection, see the following YouTube videos:
Arlo Wire-Free: Using Motion Detection
Arlo Quick Tip: Turning Motion Detection On or Off
Arlo Wire-Free: Troubleshooting Motion Detection
For more information about optimizing and troubleshooting motion detection, see the following knowledge base articles:
How do I optimize motion detection for my Arlo Wire-Free, Arlo Pro Wire-Free, Arlo Pro 2 Wire-Free, ...
How do I change the motion sensitivity on my Arlo cameras?
