Why Can't I Adjust the Default Volume for the Siren?
Oh, I forgot to mention, I have already gone into Settings -> My Devices and have selected the siren, but that just sends me to a blank screen and doesn't actually let me adjust anything.
That's just a naming capability. Any settings are in the main base section.
FWIW, you can set the volume and duration in your modes. 15 minutes isn't even a choice while the minimum of 1 minute (I think - I don't have a Pro base online to check) should be very sufficient. I understand the desire to protect your hearing but that 100dB isn't measured in your bedroom - it's close to the base itself. Smoke alarms are also similarly loud - I found one at 85 dB at 3 meters/9 feet. Closer is louder, further away is quieter. I don't see the distance at which the Pro siren is tested to achieve that 100dB but it will be close to the base.
Thanks for responding to my post. I appreciate you trying to reassure me.
Unfortunately, my bedroom is on the main floor. The Arlo base station is located just on the other side of the wall. Now, the wall may muffle the siren to some degree, but it's still too close for my liking. (And before you ask, it's not practical to relocate the base station due to the location of my internet connection.)
I also do have concern for my pets. Cats have extremely sensitive hearing and there's no way to know where they'll be relative to the base station if/when the siren is triggered.
I guess my question really is this: if the system allows for adjustment of the volume (using rules) when the siren is triggered by one of the cameras, why can't a menu option be added to allow volume adjustment for when the siren manually triggered? Many users may be comfortable with the default volume setting (and perhaps even prefer it), but some of us aren't, and it seems like there ought to be a simple way to change this.
