Buying Arlo Pro in UK and taking it to India. Can I continually video record with this system?
  • 1 Reply
  • 993 Views
sikhman
Hi Guys. I will be purchasing Arlo Pro in the UK and taking it to India . Reading the specs , I find that the recording is triggered only when there is motion and audio detected. Can I continually video record with this system ? Thanks
These are battery-operated cameras so no. The best you could do would be to use AC power for the cameras, set the system up in the UK and use a UK credit card to subscribe to CVR. Of course, you'd also need to have sufficient upload bandwidth to support the streaming since these are cloud-based.
