  • 1 Reply
  • 2580 Views
brendynpadayao
What frequency does the basestation (model VBM4000) transmit? And are there any known issues with it interfering with wifi?
The base uses the 2.4GHz band for the connection to the camera. While some folks have had to move the base away from the router, it wasn't because the base was interfering with the home WiFi but just the opposite. On the other hand, I've had a base almost touching my router's antennas for 4years with no issues.
