Hi.
Can anyone please tell me the difference between the Arlo Base Station VMB2000 and VMB4000?
Also if VMB4000 is the latest Base Station put out by Netgear?
Thanks!!
I don't know of a VMB2000 but the VMB3000 came with the Arlo HD wirefree camera kits and the VMB4000 comes with the Arlo Pro and Arlo Pro 2 kits. The VMB4000 has a slightly smaller form factor and adds a siren in the base station as well as USB backup. Apart from that, they're pretty much the same. There's also the VMB3500 which is the VMB3000 in an even smaller form factor ie no siren or USB backup
Hi and thanks for your reply.
You have explained things very well and for that I appreciate you taking the time to reply.
Thanks again ........ Appreciated!!
