Arlo Pro Not Recording
I have 10 cameras and 2 base stations (5 cameras per base station). This system has worked flawlessly for over a year, however, 3-4 months ago it stopped recording video on random cameras. I can’t pinpoint the firmware rev when the problem started happening. The camera detects fine as the still picture in the device panel updates along with the time but no video. The only way to get it out of this state is to cycle the mode (armed->disarmed->armed) then all works fine for hours until it happens again. The latest firmware is running in all cameras and base stations.
Hi dB20,
Does this problem persist if you switch out the cameras you have in that area?
Gman171,
Have you tried to reboot the base station and test again to see if the problem persists?
dB20,
When you mention you reset the base station, Did you perform a reboot by pressing the power button or did you factory reset with a pin?
dB20, Paul72388,
Have you tried to remove & re add the camera(s) to the base station and test again?
Sometimes it's just faster/easier to factory reset and start fresh to clear out weirdnesses.
Paul72388,
Do to the amount of issues described I have opened a case for you. I will contact you via private message with further information.
I am having the same issue. It only appears to be on one camera. I have done all recommend suggestions as well.
I have been having the same issue for 5 days and am currently travelling the Australian outback so am unable to reset my base. My schedule that has beem working for months suddenly disarms in the morning even though the schedule is set to be armed. I am getting notifications for motion but no video's. I have tried with the PC running chrome and the android app. I have to reboot the base every day to get it to record and take it off schedule. This is a problem as I am not always in internet range so my house goes unprotected until I can reset the base. NOT GOOD while being away for 6 weeks!
When are Arlo going to fix this issue? I am using the android app or chrome on my Windows 10 PC when I am in range of service and I am having to restart my base at least twice a day to get it to record. This issue has been going on since 30/9/18 and is still ongoing. I am away and this system is NOT WORKING AS ADVERTISED,! I am traveling the Australian outback which means I don't have internet until we get to a town which could be 4 hours away. I am getting notifications for motion but NO RECORDINGS. I have to restart the base on the app and hope it works because I may not have service again for hours. This is not protecting my house when I can't check recordings because it's not recording! If I try live view I get " there can only be 5 devices steaming at once please stop one" or something similar when there are none of my 5 camera's streaming so I have to restart base and sometimes I have to force close app to restart the base. These camera's haven't been working since that May upgrade and they are getting worse not better! I bought these due to issues with a neighbor sneaking in to my place at 4.30am and now I can't trust them to work because their not recording. If he steals anything while we are away I won't have any proof for the police which was the whole reason for getting this system. I charged my one camera that isn't connected to a power source on the 26/9/18 with the charging pod and it is now at 30% on the 9/10/18 it has the latest firmware but still seems to be draining. After the firmware upgrade it stayed at 100% for 4 days and I thought the battery drain was fixed however it's not! It has drained 70% in 2 weeks and it's not recording!
There are several threads with this same issue. I talked with support yesterday and here's what we did:
(you will lose any rules you have setup with this camera)
1. Login to your account.
2. Go to settings.
3. Click my devices.
4. Select the camera.
5. Hit remove device button.
And then Power cycle the camera:
1. Take out the batteries of the camera.
2. Wait for 1 minute.
3. Insert batteries after one minute.
4. Close battery compartment. A blue LED will blink once then off.
Sync the camera:
1. Press the sync button on the base station, just once then release. The 3rd LED from the left will flash green.
2. Press sync button on the camera, just once then release. A blue LED will blink blue slowly then rapidly.
Back to the web interface, you will need to setup any rules you had created before with this camera.
It's only been one day, but it's working so far. I will report back if it stops.
Unfortunately I am away and can't reset anything with the camera's .I am away for another 4 weeks.
