  • 1 Reply
  • 1025 Views
Trig
The web portal was working for me again when I checked on Oct 21, 2022.  Working means that the portal and the Android app match for battery level and USB storage.  Both appear to be correct data.   HURRAY!
Took about 7 long weeks, as far as I can tell to get corrected by OEM.
Dannybear
My website login now shows correct battery % but only after I used the logout all active sessions from the privacy centre.
Alas it still isn’t working for the battery status, none of my cameras are charging.
I have been waiting several months for this to be fixed, no biggy though as iPhone always shows correctly.
