Way too sensitive....help
I have the camera set to view my drive and parked cars. Trouble is, the camera is picking up every bug that flies by...night time...every 4-5 seconds. Can't seem to turn the sensitivity down.
You have to edit the sense level in the mode your using...
To change sense level;
Click on MODE
Click on BASE and modes will appear in right side column
Click on the MODE you want to edit, use ">" to edit same
you should now see the cameras, pick the one you want and hit EDIT
Drop down to MOTION is detected and hit edit again
The sense level slider is there... when you back out ( go BACK one page ) SAVE at bottom of the previous page
I have done this. I guess I am confused by the icons. Slow <--> Fast which way is less sensitive? Tried both, but still getting notifications every minute or so. When I watch live vid....I can see the small bugs...smaller than a fly....not the size of a moth or anything......🙁
To the left is less sensitive. Be sure to save after making changes. Also, small bugs are unlikely to trigger detection. Take your cameras and place them facing a wall with no motion going on. Are the recordings still occuring? If so, open a case with support.
I'm in the same boat, trying to set up a set of new cams. The driveway one watching over my shop and driveway goes off about every 10 minutes and I now have it down to 50%. My patio one is still at 80% watching over the adjoining area and it rarely goes off. I'll keep turning the sensotivity down until I get to 5% then I have to wonder, will it even pick anything up any more?
So I called support, and they walked me through changing the sensitivity levels,- this helped tremendously. One of my cameras is just super sensitive, but when the tech walked me through it, I was able to make it managable, without having to turn the whole thing off.
Also, it is a really good idea to carefully spray "Raid" or some sort of bug spray (AROUND) not on the cameras. This will keep bugs from setting it off.
Yes, did that yesterday as soon as I brought them up.
I'm still adjusting down. I'm now down to 15%, I'll see how that works out.
