Wasserstein charger no good for Arlo Pro
  • 1 Reply
  • 1222 Views
dougandersontx
I got a Wasserstein outdoor charging cable. The end does not fit very well in the camera and when it does fit, it won't power the camera when the battery is out. I would not recommend this if you are planning to operate your cameras from the power source only.
JessicaP
Hey @dougandersontx,
Make sure to use the 9V power adapter and power adapter that came with your cable with your camera. Read more here: What power adapter can I use to charge my Arlo Pro or Arlo Go batteries?
