Video glitch around the 12 sec mark
Recently I have noticed after the last couple of base firmware updates, that my cameras get glitchy video that always seems to occur at the 12 second mark on my recordings. If there is an object like a car or person in motion the video looks like it freezes or distorts and then picks up again after a couple of seconds. I tried rebooting the base but it isn't resolved. It happens on all 5 cameras. Any ideas?
Hi @JPav80
Have you tried to remove the camera from Settings > My Devices > Re-Add it?
Does the glitch appear on the app & web browser?
Are your cameras connected to AC power or are they running off the batteries?
@JPav80 wrote:
They are a mix. Some are battery only. One is in solar and a couple are powered by AC.
I asked because a couple of users have recently reported corrupted video when they used AC power, but not when they were operating on battery-only.
So if you are mostly seeing it on the AC powered cameras you might try switching to battery-only as a test, and see if that makes any difference.
@StephenB My main cameras that I use are either on battery or the solar panel outside. It isn't related to AC in my case.
Have you tried contacting customer support regarding this issue? I have attached the link here for you - Arlo Tech support
As expected it appears the latest firmware (1.092.0.24_985) resolved my issue and my recordings are no longer getting the 10-12 second mark glitch I reported almost 2 months ago.
I really wish there was better communication from Arlo regarding their buggy beta quality software. I have learned not to spend too much time troubleshooting since most issues appear related to firmware.
