Hi All.
Hope everyone is keeping safe and well.
Since the early hours of yesterday morning (25th April) UK time all of my Arlo Pro cameras have been suffering from extreme pixelation in both live view and motion detection recordings. The location of the cameras and base station have not changed for months.
The base station is VMB4000r3 on firmware 1.16.1.1_3348_facf74c
The four cameras are version H8 1.092.0.25_24_986
The pixelated video is also present on local USB storage suggesting a local issue.
I have checked WiFi strength using an analyser and all is good. All cameras have three bars in the Arlo app.
One of the cameras is within ten feet of the base station with no obstructions and is suffering the same.
I have noticed that a camera firmware update was issued in the last few days. Are there any known problems that could have caused such a drastic change in system performance?
"I have a Ring video Doorbell 2 located metres from one Arlo, and am considering replacing the back Arlo with another Ring doorbell. Both Arlo's suffer severe pixilation issues but the Ring doorbell does not...."
I need wireless, all weather operation because I use mine as critter cams outside my house.
(See: https://www.youtube.com/watch?v=KeBdIlqWGZk)
... Money is not a big object for me - is there a higher tier of products above the Arlo/Ring/Nest level? I need all-weather, wireless with a couple-hundred-foot wireless to a base-station range, day-night with good built-in IR illumination. I don't care if it uploads to the cloud or to my local network - my home network has a 4TB of RAIDed network-attached storage.
In my case, definitely not a mobile device app related as it is identical when viewed on iPhone, iPad, Windows 10 desktop or a downloaded video viewed using VLC.
Something has changed the way the video clips are recorded, which can only be firmware related AFAIK.
Colin
Not related to any app. It is the same regardless of the device being used to view the cameras and the recordings.
A quick update as it has been two weeks since my original post:
- although I have three open tickets nobody from Arlo has been in touch.
- Community managers such as @JamesC, @ShayneS and @JessicaP have been active on other posts in the forums but not on this one despite over 1000 views and over 70 replies highlighting consistent experiences since the firmware update.
- There hasn’t been a single recognition from Arlo of a problem.
Make of that what you will but I consider it to be terrible customer service.
I will echo the thoughts of others. IF there is an effort by Arlo to reduce their cloud storage costs at the expense of those who have the free seven day plan then it should be considered that we PAID for this in the upfront cost of the product. Nothing is “free”.
I have one camera that records movement during the day out of four. I am considering turning all four on to record movement constantly. That will increase my usage way beyond the 50% compression saving!
If Arlo wish to move everyone to subscription then at least have the decency to say it and provide people with the choice of a subscription for improved quality rather than throw away $1000 systems.
Until we see any movement from Arlo I suggest that everyone posts reviews on Amazon, bestbuy and other major retail outlets for the Pro and Pro 2 systems THAT THEY ARE CONTINUING TO SELL to unsuspecting new users. Hit Arlo where it hurts, how many of you would have bought a system if the reviews were full of one star ratings highlighting poor quality and terrible support?
I think the lesson here is that Arlo's problems are systemic and not always linked to one single cause. It's sad how much people spend on these products for them to not work correctly.
I am having the exact same issues as noted above, poor video quality and very low bit rate. Also, Arlo still hasn't fixed the missing preview picture in the email notifications. Has anyone filed a lawsuit or contacted BBB to get their money back on their system? This system has been degraded so much it now doesn't serve it's intended purpose as a security system.
Lastly (sorry for length), on tha App icon, it keeps adding the number of recordings so if it shows 1,000 and motion triggers another recording, it will say 1,001. I’ve deleted all recordings but it still keeps increasing like I never deleted anything. AND I HAVE NOTHING iN MY LIBRARY!!!
https://youtu.be/DENpJAuqO_c
Any help will be appreciated
I have had my Arlo cameras (original) for over 4 years, and the Pro 2 cameras & base for about 15 months, so I have a fair amount of experience with them, and this is something new.
Most of my viewing is done from a Windows 10 desktop so the app doesn't feature much in my usage at all. You may be correct in that your issue is a completely different problem - perhaps mobile device related as well.
It would be nice to hear from some of the superusers who may have some insight into this issue and what can be done to fix it. I have been on these forums for years (though not a frequent user) and it seems rare that anyone from Arlo support actually assists, so I have given up on them.
Colin
Just a little more data. @Ordinary1 described very well in Messages 6 and 8 the symptoms exhibited by my system. I also noticed:
- Both Pro and Pro 2 cameras were affected. However, the pixelation and picture degradation are much more obvious on the Pro cameras.
- As stated before, the bitrate on the Pro 2 cameras dropped from ~1000 to ~400 kbps. However, the bitrate on the Pro cameras was already ~400 kbps before the firmware update. Even so, the picture quality on the Pro was significantly better before the update.
- All local recording files, whether Pro or Pro 2, are now about 40% smaller than they used to be with all recording conditions unchanged.
- One thing did change for the better. Previously, recordings on both the Pro and Pro2 cameras would nearly always momentarily stumble (pause, jump) around 9 seconds into the recording. This showed up on both cloud and local recordings. This stumble does not appear to be occurring now.
FWIW, in case anyone at Arlo is listening and plans to address this. It really is bad now.
When I view my cameras on my smartphone, using the app, it doesn't look too bad (but that's a very small video)
But, most of my viewing of the live cameras and recorded video is via my desktop computer, using Windows 10, using both Firefox or Chrome, through the Arlo website "My Arlo", and the quality of both the live and the recorded video is CRAP.
At least the recorded video doesn't freeze, skip frames, pixelate beyond recognition like it was doing a few months back.
But I agree, Arlo did something internally a while back that caused the quality of live & recorded video to go from 1080p to far less than 720p. Because I changed nothing on my end, and suddenly after one of the updates, the quality went to **bleep**.
Wow, that is really bad.
Mine isn't that nasty, but my recorded video is fuzzy/blurry & pixelates sometimes.
I have heard others say that sometimes other things can cause interference, like a Google Home or Alexa device? WIFI router too close to the base station? DirecTV or Dish, etc.
I wonder if owners of the Arlo Pro 3, Ultra, etc. experience any of these issues? Or is this just an Arlo Pro 2 problem?
I agree bilkex, I find the exact same thing. The main reason 1080p (and 4K,etc) came along was due to the ever increasing size of out t.v.’s. The larger the screen, the more pixels needed to not get grainy and such. So Arlo’s image on our phones is ok (I still find it sub standard on night vision, should be better) but on an iPad or desktop....it’s horrible! And the pixelation is even worse. I don’t think the system can deal with the streaming very well which I believe contributes to the horrible pixelation. I know it’s nothing to do with my exceptionally strong and fast wifi.
I can live with the daytime video quality, it’s good enough. In fact people I know with other brands say my video quality it great. The night vision however it poor. And I agree with everyone that a year ago it was much better. Then at some point the night vision was REALLY bad for a few weeks, then improved somewhat to where the quality level has remained. Which I find to still be poor.
And no, nothing has changed on my end.
@Mackdiesel wrote:
Has anyone found a solution to the problem with the video seen here? This camera records 24/7, can’t figure out how to fix it. It has been months and I have tried everything.
Definitely there is loss in the captured video. In addition to the obvious corruption when the person walks down the sidewalk, there is some corruption / frame drops you can see in the moving trees later on.
If you have another camera, try swapping them and see if the problem moves with the camera (or stays with the location).
Are you seeing issues with lost connections when livestreaming?
I've had 6 Arlo Pros now for 2 years. In that 2 years, this is by and large one of THE worst firmware updates. The video quality is nothing but atrocious now. Looks like video taken on an old clam shell cell phone. Lets hope there's some class action suit over no longer providing 720p video on a system advertised to capture at 720p. I'd sign on, not to get anything out of it, but to get Netgear to rise to the occasion to fix their junk.
I won't be purchasing any more Arlo products when these Pros give up, there are much better vendors/options. I wish that would be soon so I could justify another $1000 on a home security system.
I believe that someone has already started the class action lawsuit. Hopefully the thought of having to reimburse thousands of people may change their minds. We have the data to back up that they have downgraded the qulaity (which is what we paid for). This would be an easy lawsuit to win.
We have a mix of Pro and Pro 2s. One of the Arlo Pro cameras has been in the same spot (front porch) for the past couple of years since we bought it. Taking a look at what is on the USB stick, we've taken a sample set of recordings and checked the Data/Total bit rates for recordings of similar length at similar times of the day. You can check the bitrate of these files easily on Windows 10 by right-clicking the file, selecting Properties, and going to the 'Details' tab. Here's what we found:
~3/2019, files were ~1390kbps, (example file: 3.16MB for a 19 second file)
~1/2020, files were ~700-750 kbps, (example file: 1.55MB for a 17 second file)
This month (since last firmware update), files are ~450 kbps, (example file: 1.30MB for a 21 second file)
The claimed resolution has been kept the same for all files (1280x720). Frame rates during the day have been consistent ~24/second. That is until this last update (now it hovered 23.4-23.6).
There have been no material changes in router placement, camera placement, internet bandwidth/household usage.
My best guess is that Arlo is continuing to tweak the compression to squeeze file sizes down more as much as possible. It may have gotten to the point that their compression is compromising the ability to bit-correct. Most recordings for us now require 5+ seconds to render a reasonable image, assuming no motion. Many subjects (including cars) have left the field of view by then making these cameras all but useless for real use. I can barely make out the difference between a raccoon vs. neighborhood cat at night when before I could make out the raccoon's tail markings. Our Pro 2s have seen similar relative degradation since we bought them last fall. With their poorer light sensitivity at night compared to the Pros, the compression issues have made them worse to use. This problem exists on VMB4000, as well as VMB4500.
These updates are unacceptable. (1) Pushing a firmware update to increase compression causing other issues/artifacts, (2) calling these firmware update "bug fixes" without ANY explanation of what they are fixing.
I suggest those of you who have recordings sampled over the years keep them for future reference. Raise support issues before your warranty expires (if you still are under one) to document the point in time(s).
