Hi All.
Hope everyone is keeping safe and well.
Since the early hours of yesterday morning (25th April) UK time all of my Arlo Pro cameras have been suffering from extreme pixelation in both live view and motion detection recordings. The location of the cameras and base station have not changed for months.
The base station is VMB4000r3 on firmware 1.16.1.1_3348_facf74c
The four cameras are version H8 1.092.0.25_24_986
The pixelated video is also present on local USB storage suggesting a local issue.
I have checked WiFi strength using an analyser and all is good. All cameras have three bars in the Arlo app.
One of the cameras is within ten feet of the base station with no obstructions and is suffering the same.
I have noticed that a camera firmware update was issued in the last few days. Are there any known problems that could have caused such a drastic change in system performance?
Sorry to hear abou the doorbell too! Strewth, this is just a mess.
We're now looking at the Reolink Argus wireless camera, half the price of Arlo. Just reading reviews and forums first!
@Manolo86 wrote:
Complex scenes.... So anything that passes in front of my Arlo Video Doorbell (full signal) is a complex scene?
I have never heard anyone calling motion picture/video a "COMPLEX SCENE". That is the dumbest thing I've ever heard in my life. This is serious business. Are they trying to make fun of us?
I really don't even care about cloud storage all that much. I just want access to my local storage wherever I am. The problem with that is that they can't even get that right. I had to disable port forwarding because it would screw the app up and use 85% of my battery. Not to mention the base is intermittently not recognizing my flash drive since the 5/4/20 update. I chose Arlo over other brands for the local storage option. The system is useless to me until they fix that and the pixelation.
I have also looked at Reolink and Ezviz and am trying to find a completely wireless system with good video resolution. I don’t mind paying a monthly subscription for service as long as the video is decent quality. I will not upgrade to the new Arlo Ultra given my disappointing experience with my new Arlo Pro2 system. Arlo should fix the problem they created or refund our money for these cameras.
My video gets severely pixilated at precisely the times it's needed to be at its best. Until this is fixed we cannot recommend Arlo, or post good reviews, or consider updating our systems to newer Arlo cameras and paid subscriptions. In the long run this will cost the company more than it saved. Whoever authorized this has done immense damage to the Arlo brand....
Thank You for your reply, @JessicaP . You must've drawn the short stick - sounds like you're forwarding someone else's answer that only partially addresses our concerns. One thing it does make clear is that this was done intentionally, it was not a programming error. But it still leaves unanswered:
- Why was this done?
- Why was the power management selection (best video to best battery life) apparently rendered totally ineffective?
- Most importantly, will this be fixed?
- When?
As many have stated, the video quality is now terrible and unacceptable. A good interim solution would be to roll back to the firmware version(s) in place in early April. If circumstances require that video bandwidth or cloud storage be reduced, PLEASE work with your customers prior to implementing a change so that a reasonable compromise can be reached. Conduct surveys, request suggestions, that kind of thing. I think your customer base would be a lot happier.
"Hope you are doing good. Thank you for contacting us.
Sorry that you are facing an issue with the Zoho Mail mobile app. I'll have this checked and get back to you with an update."
Appreciate your patience in this regard."
6 days later and this was their update:
"Thank you for your patience.
We have identified an issue with regard to the scenario that you have reported and our developers are currently looking into it. We will have this addressed in our future updates. I sure will followup with them and keep you apprised as and when I have any news for you on this front.
Thank you for your understanding."
That is how customer support is supposed to work! Holy crap am I impressed. I'm sending a 5 star rating their way. Arlo needs to take this example and use it in their customer support training model (assuming they have that). Hopefully Zoho will break into the surveillance camera market one day.
Here's a link to a decent primer on video compression and the handling of "scene complexity."
https://ipvm.com/reports/vbr-vs-cbr-surveillance-streaming
That link is interesting. It says that for a simple scene (like a plain white wall) 720P would need around 200kb/s (or 25kB/s), and a complex scene might need 4,000kb/s (or 500kB/s). Since 1080P has just over twice the pixels, an assumption (perhaps incorrect) might be that 1080P might require around 50kB/s for a simple scene and around 1,000kB/s for a complex scene.
My recent very pixelated video from my 1080P Pro 2 is coming in around 60kB/s which is an awful lot nearer the "simple" scene (white wall) bitrate (of around 50kB/s) than Jessica's "complex" scene bitrate (of around 1,000kB/s).
Sort of makes you think that Arlo might think we all have our cameras aimed at plain white walls and have adjusted the bitrate accordingly ?
On 12 March 2019 my Pro 2 was recording at 140kB/s (kilobytes, not kilobits), and now the same camera on exactly the same scene (it has not been moved and the scene has not changed at all) records at 60kB/s. So the quality is a fair bit less than half what it was when I bought the cameras - through NOTHING that I have done !
Is it even legal for a company to reduce the performance of your equipment like that ? Imagine if you bought a 110kW VW Golf and after a service it could only produce 47kW - I can't imagine that going too well.
@JessicaP You cannot seriously have read all of these posts and then come up with this for a reply? This is a complete cop out.
So Arlo advertises my doorbell as 2K and people look like my old NES games when they walk by because it's a "complex" scene. It's a doorbell, everything that passes by will be quick and close! They sabotaged their own products. They can't even spring for a more robust server or something? I feel this company is doomed. What a waste of time and energy.
No not legal at all, we bought a product that is 1080 it is to be that for the life of the product.
I spoke to a lawyer friend on mine about this and told me when ever I want to get the ball rolling on this to just let him know.
Very different than purposefully nerfing the video quality of your camera because they can’t afford the bandwidth or storage costs...
"Eufy
Looks like arlo, works like arlo but focuses on local storage in base unit using sd cards made by anker"
The one thing I see about Eufy cameras that I didn't like was that their cameras cannot be viewed via your PC.
To me that's a deal breaker.
@conma wrote:
About a month ago I noticed that my cameras are basically useless. Pixelating video is horrible. Sorry I recommended arlo to family members.
Same here I recommended the system to family members and a friend which all bought the system pro 2 about 8-9 months ago and now iam hearing crap about it, wish I never did now. WE NEED ANSWERS !
I have a bunch of Wyze cameras, too. The video quality on a $20 Wyze camera absolutely blows away my Arlo 2 Pro. I'm not exaggerating at all. Wyze doesn't make any direct competitors to Arlo—yet—because their cameras require USB power (I use mine indoors). But they will soon release an outdoor model and they recently released a preview. I like Wyze because they cost a fraction of their competitors and they are far more transparent and communicative with their users.
If the Wyze outdoor camera is as good as all the stuff they've released thus far, I will be ditching my Arlo junk for them to cover the exterior.
This issue has really put Arlo's problems under an x-ray machine that some of us have been on this forum for years talking about:
1) Arrogance by Arlo developers to think they can reduce picture quality to rubbish without us knowing
2) Complete lack of transparency on firmware updates. The last one that causes all of this literally said "Bug Fixes". I've included a picture from Arlo as proof.
3) Failure to address customer concerns when brought to Arlo Moderators attention. Dismissive attitude _at best_
4) "Gurus" on this forum who tell you it's your router or WiFi, wasting endless hours of people resetting their systems. Just stop it already. There are clearly some very intelligent people posting on these boards, and every voice matters regardless of post count.
Since Arlo needs cloud server space (the only logical reason they'd increase the compression a ridiculous amount), let us all utilize local storage instead. I'm more than happy to give you back your cloud storage in return, and I bet there are many others like me.
